Doing a Random Vibration analysis which uses ACP Prep to setup my composite layup. After solving, ACP Post failure plots do not look OK. For example a failure IRF plot shows all zeros.
Tagged: 18.2, ANSYS Composite PrepPost, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantUnfortunately ACP Post does not support failure post-processing for a Random Vibration analysis.
