April 5, 2023 at 2:33 pm
FAQParticipantAt 18.0 it was documented that if a model has rigid body modes RangeFact should be set higher than 2 to get accurate low flexible modes. Also the following limitations were documented in the SNOPTION command notes: 1)If rigid body modes are present in the model by which you seek for rigid body modes as a solution, the accuracy of the lower flexible modes is slightly deteriorated due to rigid body modes presented and Supernode eigensolver approximation. In this case, you should increase the values of RangeFact to be higher than 2.0 (default) and smaller than 10.0 to achieve better accuracy for lower flexible modes 2)Since the Supernode is formed arbitrarily and automatically, different domain decomposition (different number of cores in DMP parallel processing) will slightly affect the solution accuracy. However, this effect of inaccuracy is normally less than 0.1 % in eigenvalues solution. 3)Supernode eigensolver does not used equation pivoting logic to process or factorize local equations. Therefore, any a finite element formulation that requires pivoting to achieve equation solution, such as element formulation with Lagrangian multipliers (U/P formulation), will not be supported (it automatically switch to Block Lanczos modal solution in this case.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
