Does the result “Displacement after cutoff” mean that the support structure is still attached to the part, i.e. the part is only removed from the build plate when I evaluate the results?
Tagged: 19.1, Additive Print, additive-manufacturing, cloud, NA, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantAll “after cutoff” simulations assume the part is removed from the supports. All nodes are released simultaneously (not progressively).
