Tagged: 19.2, materials, mechanical, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantYes, Hill potential can affect creep calculations since the “effective stress” (Norton) term in creep will use Hill potential ratios. By default, the yield ratios are applied for both plasticity and creep. This means that the effective stress in the creep equation is based on Hill. To define separated Hill potentials for the plastic yielding and the creep flow (TB,HILL,,,,PC), issue two TBDATA commands, one to set constants C1-C6 defining the Hill yield surface for plasticity, the other to set constants C7-C12 defining the Hill potential for the creep direction. Below is an example. MP,EX,1,20.0E5 ! ELASTIC CONSTANTS MP,NUXY,1,0.3 TB,HILL,1,1,,PC ! HILL data table for plasticity and creep TBDATA,1,1.0,1.1,0.9,0.85,0.9,0.80 ! Plasticity Hill parameters TBDATA,7,1.0,1.0,1.0,1.0 ,1.0,1.0 ! Creep Hill parameters
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
