Tagged: 18.2, hyperelasticity, materials, mechanical, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantHaines & Wilson model can be taken as a special case of 9 parameter Mooney Rivlin model, see the attachments for more details
1. 2052683-01.pdf
2. 2052683.pdf
3. 2052683.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
