April 5, 2023 at 2:31 pm
FAQ
ParticipantYes – negative cross-coupled coefficient in bearing elements has a meaning. This kind of characteristic is obtained for fluid film bearing in particular. Now if those terms are very large when compared to the terms on the diagonal, then it may be harder for the solver to find solutions. In any case, QRDamp is not recommended in this case. Use DAMP as a reference.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
