January 25, 2023 at 7:34 am
FAQParticipantModel Recommendation: From a material definition standpoint, it is suggested to use the viscoelasticity material model to capture the temperature dependent relaxation of the elastic modulus under the heat load. Since it is glass, one might be able to use the TN shift function to capture the relationship between time and temperature through the glass transition temperature. Besides, it is suggested to run the model as a full transient dynamic analysis, with appropriate levels of system damping.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
