Do you have an example for employing alpha and beta damping for CMS bodies in Rigid Body Dynamics via command snippets?
Tagged: 19, mechanical, Multibody, structural-dynamics, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantYes. Please, see the attached example project. Please note, it is important to set the command snippets under the condensed parts to be sent to the RBD solver instead of to the APDL solver.
1. 2055093.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
