Do you have a simple example for a pre-stressed MSUP Harmonic Analysis with Cyclic Symmetry boundary conditions?
March 17, 2023 at 1:12 pm
SolutionParticipantYes, please find an exemplary project archive attached. Please note that the rst-file “Harmo.rst” in the user_files directory is a dummy expanded results file from some random Mode-Superposition (MSUP) Harmonic Analysis. This is just needed to get the green checkmark in the Harmonic Analysis block. Please also note, that you have to run this type of analysis in SMP (Shared Memory Parallel) mode. (Tools > Solve Process Settings > Advanced… > uncheck ‘Distribute Solution’) For more details, you can also check #2052716 – In the field of rotating machinery, customer main concern is cyclic prestressed MSUP harmonic analysis with the ability to run multiple mistuning configuration in a small amount of time https://support.ansys.com/AnsysCustomerPortal/en_us/Knowledge+Resources/Solutions/Mechanical/2052716 which goes even further and also contains the consideration of mistuning configurations. Further solutions on Cyclic Symmetry Analyses and pre-stressed Cyclic Harmonic Analyses are: #2050929 – Is there an example to demonstrate the procedure to set up pre-stressed cyclic harmonic analysis ? https://support.ansys.com/AnsysCustomerPortal/en_us/Knowledge%20Resources/Solutions/Mechanical/2050929 #2046582 – Video presentation of knowledge materials on Forced Response in Cyclic Symmetry https://support.ansys.com/AnsysCustomerPortal/en_us/Knowledge%20Resources/Solutions/Mechanical/2046582
1. 2058017.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
