Tagged: 19, materials, mechanical, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIf one already have relative moduli and relaxation times that are verified to represent the material behavior, then you can just enter that directly without the need for curve fitting. For experimentally measured relaxation data (stress vs time), one has to use the curve fitter to calculate relative moduli and relaxation times.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
