April 5, 2023 at 2:31 pm
FAQParticipantIssue: Sometimes, “Rendering Method” available under “Show Results” tool is grayed out and only “Surface” rendering method can be selected for displaying contour plots Solution: This problem can be resolved by restarting the simulation or restarting Discovery Live.
