May 15, 2023 at 8:32 am
SolutionParticipantThermal Simulation Tutorial: Learn how to do a basic thermal simulation of a heat sink with ANSYS Discovery Live.
1. 2053858.zip
2. 2053858_Captions_JN.mp4
