September 26, 2022 at 9:59 am
FAQParticipantProblem: If Discovery Live is installed on a network drive, it is observed that the application crashes or user cannot perform operations like selecting faces during enclosure creation in fluid flow setup and so on.
Cause: This may happen due to one of the xml files not getting copied from network drive to local drive
Recommended solution: To overcome the above mentioned problem, copy file named “MaterialLibrary.xml” from ~
Ansysv191scdmMaterialLibrary to %AppData%RoamingSpaceClaimDiscoveryMaterialLibrary
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- FAQ: Missing Areas of the User Interface in Discovery Live
