May 15, 2023 at 8:32 am
SolutionParticipantThis video explores static structural simulation of an assembly of bodies using pressure loads, displacement controls, and rotational velocity loading. The video also shows how to pass the simulation setup to Discovery AIM for more advance physics simulations in the Discovery Suite.
1. 2053386_Captions-CN.mp4
2. 2053386_Captions-EN.mp4
3. 2053386_Captions-JN.mp4
