May 15, 2023 at 8:32 am
SolutionParticipantThis ANSYS Discovery Live video shows part 2 of how to use the following tools to create a Phillips-Head screwdriver: Sketch, Pull, Move, Blend, Pattern, Revolve, Combine & Round. Please watch part 1 to learn how to create the Flathead screwdriver, which is the basis to start the Phillips-Head screwdriver
1. 2053380_Captions-CN.mp4
2. 2053380_Captions-EN.mp4
3. 2053380_Captions-JN.mp4
