September 26, 2022 at 10:00 am
Watch & Learn
ParticipantANSYS Discovery Live offers real-time simulation that is fast and interactive. Make changes to the geometry, physics and results to better understand your design and its performance relative to multiple design changes, in real-time. Watch these videos to gain an understanding of what ANSYS can help you Discover.
1)Â Interactive Geometry
What if you could make a simple or complex change directly on a 3-D model, and instantly know the impact of that change? With Discovery Live fluids results instantly adjust as any geometry changes. Structural simulations re-compute to instantly show the changes in stress and deflection because of your iteration. Discovery Live lets you not only digitize your idea as you have them, but the interactive geometry gives you invaluable feedback in how your design will perform.
2)Â Interactive Physics
Interactive physics in Discovery Live means answers to your what if questions. It lets you change input parameters on the fly, or instantly switch between physics types and solutions. Discovery Live gives instant answers to questions like, what’s the effect on deflection if a part were made of Steel instead of Aluminum? Or what happens to the heat dissipation if the heat flux suddenly increased? With Discovery Live you can spend more time with questions and answers and less with setup and configuration.
3)Â Interactive Results
Discovery Live is not only equipped with powerful rendering capabilities, but they’re interactive. The unique render types, interactive range settings, and dynamic numerical feedback propel you to discover insights into your product’s performance. Changing the size of bounding box, or the characteristics of streamlines are just a few options to help you find trends in your designs.
The dynamic controls of Discovery Live let you see only what you want, and how you want it.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
