May 15, 2023 at 8:32 am
SolutionParticipantDiscovery Live is a groundbreaking approach to design, allowing anyone to incorporate engineering simulation earlier into product development. It’s lets uses ideate, innovate, iterate and test their concepts and design direction like no other product let’s them do. Check out attached video for more details.
1. 2056041.mp4
