September 26, 2022 at 10:00 am
SolutionParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
Consider the rectangular bar pictured below with a length of 120 inches and a height and width of 5 inches. One end of the bar is subjected to heating and can be assumed that said end is at 400 degrees Fahrenheit. The other end of the bar is exposed to the environment which is assumed to be at room temperature (80 degrees Fahrenheit).
In this tutorial, we will utilize Discovery AIM to find the temperature throughout the bar and total heat flux.
Geometry
In this video, you will learn how to create bar geometry required for the analysis.
Mesh
In this tutorial, we will be using Physics-Aware Meshing. Physics-aware meshing helps automate and simplify your problem setup. With physics-aware meshing, the computational mesh is generated automatically based on the solution fidelity setting and the physics inputs.
Physics Setup
In this video, you will learn how to define temperature at 2 ends of the bar.
Results Evaluation
In this video, you will learn how to check the temperature distribution, total heat flux and heat flow reaction in the model.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
