Tagged: aim tutorial, discovery-aim, electromagnetics, fluids
September 26, 2022 at 10:00 am
Solution
ParticipantThis example is taken from Cornell University’s ANSYS AIM Learning Modules
Problem Specification
This problem is intended to address the questions of force calculations as well as modeling of permanent magnets in asymmetric and three dimensional geometries.The spool is made out of brass, the coil is made out of copper and the magnet is made of NdFe30 (Neodymium Iron). In this demonstration, two cases will be considered and the force between the magnet and the coil will be determined.
f = f(i,R,s)
where
f = force between magnet and coil i = current, R = horizontal displacement  s = vertical displacement
In case one, both s = 0 and R = 0.254mm are held constant. Therefore, f = f(i)
In case two, s = 0mm and i = 50mA are kept constant. Therefore f = f(R)
In the first case, the current will vary from from 0-100mA in 10mA intervals. In case two, the axial displacement will vary from 0.0-.5mm in 0.05mm intervals.
Pre-Analysis
Governing Equation
Magnetostatics is the study of magnetic fields in devices where the magnetic field is generated from DC (steady) currents and/or permanent magnets.  Magnetostatics is a special case of Maxwell’s equations, which form the basis of electromagnetism.
For magnetostatics the electric field inside of a current carrying coil is completely decoupled from the magnetic field, and the following Maxwell’s equations are solved for magnetostatics –
Where ∇ denotes divergence, H is the magnetic field intensity, J is the current density, and B is the magnetic flux density.
Geometry
In this video, you will learn how to import the geometry and how to define a parameter for the distance between the magnet and spool.
Physics Setup
In this video, you will learn how to:
- Assign material properties
- Define boundary conditions and parameterize current
- Define output parameter for force magnitude
- Define design points
Design Point Study
Case 1:Â The current will vary from 0-100mA in 10mA intervals
As shown in the above video, all the 10 DEsign Points are updated. The force results will look as shown in below image.
Case 2: The axial displacement will vary from 0.0-.5mm in 0.05mm intervals. In the design parameters dashboard, change all the current data points to 50mA. Then iterate the horizontal data points from 0.05mm-.5mm by 0.05mm. Click update all to see results. The results will look like shown below.
Results Evaluation
The following video shows how to compute Magnetic Flux Density
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
