April 11, 2023 at 11:48 am
Watch & Learn
ParticipantThese video tutorials will expand your learning with ANSYS Discovery AIM with content specific to mechanical design. Structural Tutorials begins with an introductions to the guided workflow and the the following videos dive deeper into more advanced simulations and control.
1) Structural Simulation: Learn the basics of how to setup, solve and visualize the results of a structural simulation.
2) Structural Assembly Brace: Learn how to setup a structural simulation of a small brace assembly by specifying inputs, contact conditions and material. See how to mesh and visual the stress and deformation in the model due to loading.
3) Structural Assembly Manual Meshing: Learn how to set meshing controls in a structural simulation of a simply assembly to properly refine the mesh in the appropriate areas. This video shows how to capture areas of detail and points of interest while minimizing processing time.
4) Insertion Force Prediction: Learn how to simulate the insertion of a plastic buckle in order to predict insertion forces, using non-linear contact between the 2 bodies.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
