September 26, 2022 at 10:00 am
Solution
Participantpipe-and-butterfly-valve-assembly-files.zip
This Discovery AIM tutorial shows a structural analysis of a pipe assembly loaded by fluid flow and thermal effects. The simulation demonstrates the use of a custom template (developed by a methods engineer) and expressions to streamline the simulation process for rapid design of a piping assembly by a non-expert. After running the custom template, the design engineer is only required to follow the To Fix directions in the UI to assign locations and complete the analysis.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM – Scaling deformation contour results
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- How to setup a Parameter Study
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
