Direct import into Mechanical of 3rd-part formats (e.g., iges, step..)with touching or near-touching 2D bodies are merged into one body. How to overcome this issue?
Tagged: 18.2, designmodeler, General, import, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantOne way to fix is to import into Design Modeler first. In the Details of the Import feature, set the “Stitch surfaces” to “No.”
