March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attached documents to accesss the solution. Keywords: Interference fit, WB LS-DYNA, Dynamic relaxation.
1. 2061096.zip
2. 2061096_Solution.pdf
