May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim’s Beam Extract tools allow for beam profile customization. The attached video demonstrates how to extract a beam profile from a solid and then edit the profile.
1. 2052900.zip
2. 2052900_Captions-EN.mp4
