May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim hosts a number of 2D sketching and 3D modelling tools to quickly create geometry from given reference dimensions. Attached video demonstrates one such geometry creation example. Keywords: sketch, pull, dimension, geometry creation
1. 2052806.mp4
