May 15, 2023 at 8:32 am
SolutionParticipantAttached video explains how to create solid geometry from STL model of a lever. The process involves use of sphere tool to quickly recreate spherical sections and then extract blade curves and pull them to create solid geometry Keywords: STL, facet, sphere, extract curves, pull, reverse engineering
1. 2052799.mp4
2. 2052799.zip
