May 15, 2023 at 8:32 am
SolutionParticipantSpaceClaim offers intuitive tools that are perfect for reverse engineering. Attached video demonstrates how to orient STL model, extract curves, create solid and edit it to match the underlying STL model. Keywords: STL, facet, orient, extract curves, fit curves, pull, reverse engineering
1. 2052796.mp4
2. 2052796.zip
