Could not start the memory inquiry solver: check distributed installations, MPI availability, MPI authentication and firewall settings
February 6, 2023 at 2:42 pm
FAQParticipantAutomatic settings require MPI. Also, this is not supported in heterogeneous environments i.e. all solvers should be either Windows or Linux. Uncheck “[x] Use Automatic Settings” and manually specify the number of tasks and cores.
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- What are the available boundary conditions in Maxwell?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
