Tagged: 2019 R2, General, structural-mechanics, system-coupling
January 25, 2023 at 7:34 am
FAQParticipantThe Fluent and MAPDL solvers can generally share cores if you have sufficient RAM. E.g. if you have an 8 core machine, 8 for Fluent and 6 for MAPDL is OK When Fluent is solving and MAPDL is idle, the MAPDL solver processes will use almost no CPU When MAPDL is solving and Fluent is idle, the Fluent solver slave processes will use a small amount of CPU (perhaps 5%)
