April 13, 2023 at 7:33 am
SolutionParticipantPlease refer to the attachments to access the Solution. The video was done in a previous version but it is still valid in 2019R1. Shortcut keys are Ctrl+C to copy, Ctrl+V to paste or Ctrl+X to cut.
1. 2043829.flv
2. 2043829.pdf
