Tagged: 17, apdl, General, mechanical-apdl, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantNo. The EKILL command may be used in static and nonlinear transient analyses where the Newton-Raphson solver option is set to full explicitly in the first load step. In Ansys, modal analyses are linear by definition.
