June 6, 2022 at 9:58 am
FAQParticipantFrequency response is not available for total deformation in ANSYS Mechanical. The frequency response outputs the amplitude of the scoped area in one direction. For example, if there is frequency response from the X direction and Y direction, the maximum deformation/amplitude value in X and Y direction actually may not happen at the same time if there is a phase difference. In other words, when the node reach its maximum total deformation, the contributions from X and Y direction are not necessary the maximum from the two directions, so it is not correct to combine the maximum X and Y amplitude values directly.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
