Can we directly use Total stress vs Total strain curve for my multilinear isotropic hardening plasticity model?
Tagged: 19.2, materials, mechanical, Nonlinear mechanics, plasticity, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantIn workbench engineering data, multilinear hardening curve requires plastic strain vs stress data. To define total strain vs Stress data, we need to use apdl commands under the body. Uniaxial test data can not be utilized for this model in workbench.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
