April 13, 2023 at 7:33 am
SolutionParticipantYes, it is possible to define stiffness/damping as a function of time in RBD. One can either writing the python script directly or using the variable load extension. Attached is a simple test case. It defines time varying stiffness or damping using Python table. Note that this model needs to be solved in meters. Reference: help documentation for Variable Load extension: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/wb_sim/rbd_using_var_load_ext.html
1. TimeDepStiffDamp_v221.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
