Tagged: 19, DMPOPTION, General, mapdl, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantYes, starting R19, user can now combine local results files into a single, global results file during a distributed parallel solution. A new option on the DMPOPTION command can be used to control this. Using the global file can facilitate postprocessing while a long-running distributed-solution progresses.
Reference DMPOPTION in v23R1 documentation: https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/ans_cmd/Hlp_C_DMPOPTION.html
