General
General
Can the ANSYS nCode DesignLife FEOutput glyph be modified after the solution?
    • FAQFAQ
      Participant
      No. FEOutput must be attached before the solution. However, the model and results are automatically saved to the binary file.fer file. If you need to create an output file after the solution is finished, you can drag the file.fer onto a blank workspace and connect it to a FEOutput glyph. You can then use FEOutput to create output files from the file.fer file.
