June 6, 2022 at 9:58 am
FAQParticipantYes, beam elements can have orthotropic elastic material. However, beam theory leads to a reduced stress/strain tensor and some orthotropic material directions are actually neglected due to the use of beam theory. For BEAM188 (BEAM189 for higher order beam), the Material Properties listed include Ex, Gxy, and Gxz (x is along the beam length). Therefore, given orthotropic material, Ey and Ez are not actually used in the beam element and not even Gyz. However, the Shear moduli Gxy, and Gxz can be different.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
