Tagged: 18.1, apdl, General, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantHere is the location which you can search in Help: This section describes all looping in APDL. ANSYS Documentation // Mechanical APDL // Ansys Parametric Design Language Guide // APDL as a macro language // Controlling Program Flow in APDL.
