March 17, 2023 at 8:59 am
FAQParticipantYes. With the default setting of SUMTYPE,COMP, the component stresses are averaged at the nodes and SEQV is calculated from these averaged component stresses. If SUMTYPE,PRIN is issued, the component stresses are set to zero and the equivalent stresses are directly averaged at the nodes, because the component stresses aren’t available.
