Tagged: 19, materials, mechanical, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantCurrently, the only kinematic hardening model that can be used in conjunction with an isotropic hardening model is the Chaboche model, which is nonlinear. However, it is possible to simplify the Chaboche model to a bilinear kinematic model by choosing n = 1, where n is the number of material models, and gamma_1 = 0, where gamma_1 is the rate of decrease of the hardening modulus.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
