Can I obtain a factored strain energy? When I specify a non-unit value of FACT on the SET command, the strain energy is zeroed out.
Tagged: 6.1, General, mapdl, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantNo. Strain energy is a non-summable miscellaneous item. Strain energy is equal to 1/2(u’ku). A factored displacement solution would produce a factor**2 *strain energy.
