March 17, 2023 at 1:12 pm
SolutionParticipantYes, take a sinusoidal acceleration with 100Hz as an example , you can click on the right end of the input field of Magnitude and then select ‘Function’ to enter the acceleration profile generally sine curve “sin(2*3.1415926*100*time)”. See attached picture below. You can select either Degree or Radians from the pull-down menu Units in Mechanical GUI. You can also define how many points are used to get the tabular data of the function. Program will calculate the tabular input automatically based upon these input.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
