General
General
Can bookmarks and annotations in the ANSYS Help be carried forward to the next release of help?
    • FAQFAQ
      Participant
      Moving favorites/bookmarks from one release to another is not supported. That being said they are stored in a separate file under APPDATA: %APPDATA%Ansysv1xxanshelpFavorites.xml In theory, you may be able to copy the Favorites.xml file from previous release to the new release’s %APPDATA% folder. Of course it is not tested or supported. About Annotations, yes it can be carried forward. Instructions are in ANSYS Help at “help/viewer_help/vhlp_annotations.html.”
