Tagged: 17, Ansys nCode DesignLife, DesgignLife, fatigue, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantYes. The Frequency Spectrum Glyph can be used to convert a Time Series Input loading to a PSD.
