Tagged: 16.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantIt depends if the DesignLife system is linked to a Mechanical system on the Workbench project schematic. When linked to a Mechanical system, ANSYS nCode DesignLife is hardwired to use only one workspace, which will be named WS1. If multiple workspaces are created or WS1 is renamed, the fatigue analysis will solve within DesignLife, but the Workbench links will not update. If multiple workspaces are needed, you should create a Workbench system for each workspace.
