Tagged: 16.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantMaybe. DesignLife does not have a specific brazed joint analysis technique. However, the brazing process typically produces a smooth exterior surface, with minor initial surface cracks and few or no heat affected zones. Thus, the standard stress-life approach is usually applicable if sufficient test data is available to construct the appropriate S-N curves.
