Tagged: 19, Ansys nCode DesignLife, DesignLife, General, S-N curve, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantNo. The ANSYS nCode DesignLife/Workbench plug-in expects that the S-N curve is defined in Engineering Data using a table. It cannot read the linear and bi-linear S-N curve options added in R18 to be used with the vibration fatigue capability in the Mechanical Fatigue Tool.
