May 15, 2023 at 8:33 am
SolutionParticipantThe Larson-Miller Parameters are derived from a general expression of the Arrhenius Equation. We do not have a creep material model expressed directly in terms of the LMP data, but we do have three expressions for the Arrhenius equation. (TBOPT=2,6 or 13). One could conceivably back calculate the parameters for Arrhenius equation from available LMP data. See attached derivation.
1. 2007615.PDF
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
