Can ANSYS Composite Prep Post (ACP) map the composite layup to an existing solid mesh generated outside of ACP?
Tagged: 19, ANSYS Composite PrepPost, General, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantYes, Please see the attached document and video for details.
1. 2053446.mp4
2. 2053446.pdf
