Tagged: 17.2, Ansys nCode DesignLife, DesignLife, fatigue, General, nCode, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantYes. The steps required to create a new material database in DesignLife are explained well in the Materials Manager User Guide (matmans.pdf). Those steps are essentially: 1.Open nCode 2.Open Materials Manager 3.Pick – Create new database and give it a unique name 4.RMB on database name and “Add Data” 5.Pick the Dataset Type – essentially the type and format of the test data (probably something like nCode SN R-Ratio Curves) – and give the material a name 6.RMB on database name and “Add Data” 7.Enter remaining data
